Odd Oval Shape
monlover
Model of CNC Machine: Omnitech 4X8 with 8 tool
Re: Odd Oval Shape
Post by monlover »
Hi Every one
Thank you very much for your responses and your help
got so busy day at the shop got another fish to fry see attached please, and started now re working at this file and just did the Backed option , the result is great. :)
I did so many manual tries to get the slop as close as possible to what I what.
I mean the depth .
let us say, Material thickness is 1" inside slot depth needed at low end is 1/2" and outside slop needed dip is 1/8" now, at the modeling section property, what is the shape height i should enter?? 7/8?? since the outside high side is 1"-1/8" = 7/8 " Correct??
and at the toolpath level at the right side when i click on Set, i can see an error and material height is a way exceed the 1" so i have to set it manually using Gap above material option. is it how it has to be?
Thank you in advance
Tex_Lawrence
Model of CNC Machine: Shapeoko 3 XXL; V-Carve DT 10.509
Re: Odd Oval Shape
Post by Tex_Lawrence »
highpockets wrote:
Tue Oct 06, 2020 9:07 pm
... Once baked you CAN NOT go back to the original ingredients, it's a cake ....
Perfect analogy for my brain to wrap around. +1 Thanks!
Crooked Wood Products - Custom Wood
Truth lies dormant in our future history ― Tex LXVIII
