HI.
I don't understand the effects and interplay between the modelling plane. zero plane and the job - both the model and the blank.
I have traipsed through the instructional material but not found one that highlights the above.
Most seem to gloss over the settings and effects in pursuit of the finished model.
Please suggest a Vectric tute that will help me get to grips with this,
The specific problem I'm trying to eliminate is cupping but I think I need to understand more rather that just fart about and hope.
recommended tutorial
Re: recommended tutorial
On your finishing pass offset outwards by a little more than 1/2 of the bit diameter.The specific problem I'm trying to eliminate is cupping
- Model of CNC Machine: Chinese 6090
Hi Randall.
setting an offset in the finishing toolpath form doesn't produce a a change - That's why I think I'm missing something in the set up with the modelling plane.
I;ve tried adding a zero plane - but I really don't understand what I'm doing - so I'm hopeful there's a tutorial with a greater focus on the setup, modelling plane and zero plane.
the ' just add this' or 'do that' isn't helping.
Of course it's always possible that I understand far less than I believe I do. )
- sharkcutup
Can you post your .crv file here on the forum? Provided there are no copyright material within!
The Forum members here can dissect your file data to determine what may help you. Someone may even make the necessary changes and post the file back here on the forum so that you can download it and review what was done to the file to make it work for you.
They may even take the time to show/help you understand what is necessary to get the project to work. There are a lot of helpful forum members here that can provide input to help you understand the process.
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
Here is an explanation of when a zero plane is helpful: Identifying and eliminating software generated chatter marks
Note that it was written before the term "zero plane" was adopted.
