Fun with a point roundover bit
Using a Magnate 0.25” radius point roundover bit on Medex MDF
Re: Fun with a point roundover bit
Before sanding
- scottp55
NICE Unique result Randall!
Pretty versatile bit for lots of different things:)
NICE job!
NICE job!
R.N.
R.N.
- Aussie
- Model of CNC Machine: Robotics Model 8
Really nice..... just need a project to use it
Ron
Crafers Crafts
Crafers Crafts
- mtylerfl
That is really nice, Randall!
- Tex_Lawrence
Getting that cut out without breakage overshadows the use of the roundover bit. Amazing.
Tex — Crooked Wood Products
- Model of CNC Machine: shopbot desktop
Hey Randal, pretty fancy stuff. I use that bit a lot, love it
The material is 0.75" Medex MDF. I've also cut these in 1" thick 15 lb sign foam.Getting that cut out without breakage overshadows the use of the roundover bit. Amazing.
I used a 0.25" end mill to cut around the project leaving a 0.01" skin.
Then I used a 0.125" end mill with a 1" length of cut.
Since the larger end mill had removed the bulk of the material the smaller end mill could get into the detailed areas with minimal load.
I've attached a tutorial and an example file.
- Name Signs Using a Point.pdf
- (1.6 MiB) Downloaded 334 times
- James.crv
- (1.05 MiB) Downloaded 151 times
Well done, thanks for sharing the PDF and the CRV.
Phil
Phil
- mikeacg
- Model of CNC Machine: Camaster Stinger, Sidewinder, SB 4x4
Randall,
I have one of those bits but have never used it like this! Very cool looking! Thanks for the PDF to keep me looking for opportunities to try this...
- Model of CNC Machine: Camaster Stinger SR24
Who knew you could make such cool signs with that type bit? I have one and NEVER thought to do this.
Thanks for the nudge to try something new and for generosity in sharing the technique you used.
Im am constantly amazed at the talent and generosity of the folks on this most excellent forum!
Joe
- SteveNelson46
Always looking for new ways to make lettering
Looks great and added to my todo list.
I learned about this years ago from Joe Crumley over on the TalkShopBot Forum.Thank you for sharing your knowledge, Randall
