Fillet problems
- Model of CNC Machine: opensource
Fillet problems
Can some check the attacked toolpath and see why it wont run? Fillets problem again...Thanks
Re: Fillet problems
Use the Vector Validator tool when you get unexpected problems like this. The vector on the right hand is doubling over itself so will cause you problems.
If you go into node edit mode, hover over that span and press D it will get rid of it and the fillets on either end can be removed/added without issues then.
Re: Fillet problems
Great.....Worked perfectly. Thanks, Adrian!!!!!
