Does anyone know if there is a way to use the vcarve toolpath but without the emptying part i just need the profile and for it to sharpen the corners.
v carve toolpath
- Model of CNC Machine: felder HO8
Re: v carve toolpath
You could offset a vector inside the outer one and select those two vectors to machine between.
A profile toolpath setting the sharp corners options could also work depending on the look you're going for.
- FixitMike
Use the VCarve toolpath. Use a V bit and a small diameter clearance tool. Run only the VCarve toolpath, not the clearance path.
There is also the "Corners" option if you use a Profile cut with a sharp V-bit
Oops! Adrian was ahead of me...as always....
...joeOops! Adrian was ahead of me...as always....
- FixitMike
That option isn't visible to me unless I click on the ">". I wonder what else I've been missing.
