Vcarve Is Barely Scratching The Surface
- Model of CNC Machine: MillRight Mega V
I'm obviously missing something here. I carved this two other times, one a test cut and the second needed a little change in the layout. So this is my third carve. zero position is material surface. I zero the V bit at the datum and using a piece of paper I get the Z zeroed out. I run the carve and the bit hardly scratches the surface of the board. I put a steel ruler on the board the surface is flat. I zero the Z off the general area where the vcarving will take place, same result. Checked the see that the bit was tight, it was. I'm lost here. Attached is the CRV file.
- Lewis and Clark Seal.zip
- (1.74 MiB) Downloaded 61 times
Re: Vcarve Is Barely Scratching The Surface
Those are very shallow cuts (4/100" at the deepest point) so you would need to be spot on with the z-zero. I know you said you had cut it twice before but all I can think is that it's the z-zero setting that is the issue.
Looks like your right, I guess I lucked out the first two times when I set the z height.
