Must have missed that Ted. I just woke up
What do you do while the CNC is running?
- Leo
Re: What do you do while the CNC is running?
NOPE - not yet anaway
Put my noise canceling headphones on, lean back, feet on the table, and listen to music. The headphones leak enough machine noise to hear in the background if something is going wrong. Best suited: Hard Rock, Reggae, Irish Folk and Bluegrass. Well any kind of loud music.
Occasionally check the phone or browse a forum or look up some internet news (the latter not so interesting lately). Maybe sand something or other stuff that does not need much focus. My machine jobs usually take only between 5 to 45 minutes. Would not work well for 24-hour jobs.
Tex,Very interesting clamping jig you're using. Are those plastic tubes or metal?
This is a go bar deck. It is handy for gluing things that are irregular and/or not flat. In this case the wood is sitting on a dish with a 15' radius to give the back of the guitar some curvature. The brace wood has been sanded to conform to the 15' curve too.
The rods are 0.125" OD solid fiberglass rods that I purchased from goodwinds.com. In retrospect I probably should have gone with 0.250" rods.
Some people use adjustable curtain rods that are spring loaded.
Bamboo rods can also be used, but may be more prone to breaking than modern materials.
- Tex_Lawrence
Well, while my machine is cutting, I'll do what I always do ... look for "Go Bar Clamps!" or something else I've picked up here. Some form of that will solve one of my wood clamping problems where I only want to clamp surface stock until the glue sets. Thanks!
This is a project I worked on; viewtopic.php?f=5&t=34772 while my machine was carving this; viewtopic.php?f=5&t=34621.
I'd like to take a nap but the machine would keep me awake.
phil
phil
- Model of CNC Machine: diy 4 X 4 CNC Router
Prep more wood for next project, surf the net, check the phone.
Today unloaded 25 used raised panel cabinet doors free I picked up earlier this morning.
mark-s
mark-s
- jimandi5000
Clean the shop.... that is what tell the wife Watch YouTube videos
Jim
Jim
- Model of CNC Machine: Home built cnc router using Masso G3.
Jim.jimandi5000 wrote: ↑Mon May 25, 2020 4:12 amClean the shop.... that is what tell the wife Watch YouTube videos
I thought you'd be spending time creating your gadgets.
Awesome job on that, by the way.
- jimandi5000
Thanks!ozymax wrote: ↑Mon May 25, 2020 9:55 amJim.jimandi5000 wrote: ↑Mon May 25, 2020 4:12 amClean the shop.... that is what tell the wife Watch YouTube videos
Jim
Jim
I've had very good success with fiberglass driveway marker rods. Real cheap too!Rcnewcomb wrote: ↑Sun May 24, 2020 8:17 pmTex,Very interesting clamping jig you're using. Are those plastic tubes or metal?
- mikeacg
- Model of CNC Machine: Camaster Stinger, Sidewinder, SB 4x4
I have to go with Leo on this one! As many years as I have been running my CNC machines, I am still fascinated by seeing the bit go up and down, left and right... I always have my tablet with me out there so I do get a great deal of reading done (Kindle app). My jobs tend to go long but, even with ear plugs in, I can still hear any sound variations from the spindle or bits to catch it if something goes south...
- rscrawford
- Model of CNC Machine: CAMaster Cobra 408 ATC, ShopSabre IS408
I start sanding parts while other parts are cutting. Building furniture, the CNC cutting is the fastest part of the job usually. While one piece is cutting I'm either jointing and planing and gluing up the next blanks, or sanding the last parts to come off.
I try to time my cuts so that they take about the same amount of time as my pre-assembly sanding. So if I'm building 8 chairs, I cut the legs and try to time it so that I can have one set sanded by the time the next set comes off. There is always a balance between taking longer on the CNC and getting a more finished part, or cutting more quickly and have a little more sanding to do. If I get the balance just right I don't waste any time sitting around, and the work gets done the most efficiently.
Russell Crawford
- Model of CNC Machine: laguna swift 4x4
After reading Russel's post----
Guess I'm lucky I'm just lazy like to watch the spindle go
round and round. Oh and post stuff on the forum.
- jfederer
- Model of CNC Machine: CanCam D23M
Coming from a software development and volunteer management background, I have to quote Fox Mulder... "Trust No-one". Certainly I don't trust my very capable CNC machine. I seldom leave the building (stand-alone workshop) unless nature is calling very loudly. So I usually stay in the power machine room, sanding previously made parts. Sometimes I'll go to the "no power tools" room (AKA office) and do something on the computer like check the next file. If it's a short-run job, I'll just monitor it. If I'm not sure of clearances or feed rates, I monitor it with my thumb on the e-stop button. In any case, I always start all jobs with my thumb on the e-stop button. Because... X-Files.
Joe Federer
www.federer.ca
www.federer.ca
