Cutting a 3D profile along linework
CanisLupus
Model of CNC Machine: CAMaster Stinger II (SR-44)
Post by CanisLupus »
How do I cut a 3D profile (varying Z-values) along some linework? Imagine sinuous, meandering linework in the X,Y direction with Z-values that undulate like rolling hills. I'd like to avoid creating a 3D model. It seems like something I should be able to accomplish with toolpathing but I could create a 3D if that's the only solution.
In the attached image, the lines represent the X and Y directions (a top or plan view).
Scott
Re: Cutting a 3D profile along linework
Post by Rcnewcomb »
Won't the Create Vector Texture tool do what you want?
10 fingers in, 10 fingers out
another good day in the shop
Post by mtylerfl »
Rcnewcomb wrote:
Fri May 22, 2020 6:20 pm
I think that the illustration is a “side view” of the material. I take it that the curvature is going up and down in the Z axis. (I’m not sure)
Post by mtylerfl »
Here's a cutaway side view of what I think (??) is being described. I had to make an underlying model to profile this with the Z undulations.
(included a non-cutaway view screenshot, too)
Post by mtylerfl »
I re-read the original post. I’m befuddled what is actually wanted. Could you provide a sketch of some kind to clarify a bit more? ...or maybe I’m the only one “not getting it”!
adze_cnc
Post by adze_cnc »
mtylerfl wrote:
Fri May 22, 2020 6:39 pm
Michael: The original poster mentions (parenthetically) that it is the plan view.
Original Poster: read up on the moulding toolpath. If you had Aspire (or a third-party 3D package) you could model this with a “2 rail sweep”.
Steven
Post by mtylerfl »
Yeah - top View - but wants up/down Z, etc.
I’m still not clear exactly what the goal is, though.
dealguy11
Post by dealguy11 »
Check out the Texture Toolbox gadget. It may do what you want:
https://gadgets.vectric.com/V10/texture_toolbox.html
Steve Godding
Post by mtylerfl »
Oh my goodness! Is that all the OP is wanting to do? I certainly missed the boat.
I’ll use ScottP55 excuse - not enough coffee today :D
Post by Rcnewcomb »
Post by mtylerfl »
:D
CanisLupus
Another example, let's say I have a straight line 10 inches long. I want to create a toolpath to run a bit along the line. I won't be cutting through the material but rather creating a channel. The depth of cut (DoC) will change at various points along the line with smooth transitions (no steps) between.
The desired toolpath will start at 0" with a DoC of 0.125 and smoothly ramp to 4" where the DoC is 0.500, then smoothly transition to 6" where the DoC is 0.250, then smoothly transition to 9" where the DoC is 0.375, and finish by smoothly transitioning to 10" where the DoC is 0.250. The number of points with a known DoC is not fixed and I might have more or fewer points of known DoC along the line.
The image included in my original post shows the TOP or PLAN view. In that example, I would be creating two toolpaths - one for each set of arcs - and each toolpath could have different DoC along it.
CanisLupus wrote:
Fri May 22, 2020 3:39 am
Scott
Post by mtylerfl »
Sorry - on my way to Jamaica for some Blue Mountain coffee...
Post by Rcnewcomb »
I don't know your programming skills, but I'd probably set up a spreadsheet that does the math and generate the G code from the spreadsheet.
CanisLupus
I could develop a programmatic solution. That's not an option I considered. I'm still holding out hope for a built-in solution since my linework is rarely straight lines.
