Spoil Board Resurface Question
- Model of CNC Machine: MillRight Mega V
First time resurfacing a spoil board. A new piece of 3/4" MDF, what would be a good starting depth to remove?
Re: Spoil Board Resurface Question
I usually draw pencil lines all over mine and then take off 0.01" at a time. I repeat if the pencil lines are not all gone. Hopefully you're talking about a new piece of MDF you added and not the original bed.
Gary Mitchell
Kentucky, USA
Kentucky, USA
Yes, a new piece on top of the aluminum bed.
We remove .01", then flip it, and remove .01" from the other side.
- sharkcutup
ger21
WHY both sides???
Sharkcutup
WHY both sides???
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
- TReischl
He might do it for a couple of reasons. But, since he runs a big honking industrial router my guess is so that they can pull a vacuum through it. Or, some things tend to warp if you only remove material on one side.
Ger21: Need to have a conflab with you so will be sending a PM to get your sage advice and words of wisdom, etc.
Yes, to pull vacuum through it. You need to surface both sides to get better airflow through it.
