Text on a curve
grey_justice
Model of CNC Machine: WorkBee
Text on a curve
Post by grey_justice »
Hi all, I'm trying to recreate a version of this clock as I like the way the digits hug an inner and outer circle.
I've tried to use the text on a curve and copy along vectors functions in VCarve Desktop but am struggling, any ideas how it can be done?
gkas
Re: Text on a curve
Post by gkas »
The key to doing this is 'Circular Copy'. Put a small dot at 12, then circular copy it 60x. Put a large dot at 12, then circular copy it 12x. Delete the 'extra' small dots from the hour positions. Now put a 'I' at the 12 o'clock position. Circular copy that 12 times. Now, go around to each numeral and change the text. You don't even have to close the text edit box. Just highlight the next numeral, and the previous one is saved.
Roman Numerals.crv
(823.5 KiB) Downloaded 26 times
grey_justice
Re: Text on a curve
Brilliant, I'll give it a go and share my results once completed. Thanks for your prompt reply.
springer668
Model of CNC Machine: shapeoko 3
Re: Text on a curve
Post by springer668 »
i understand that to place text on a circle, you need to first cut the circle in half. how is that done? do you need to then join the 2 halves afterwards? thanks
Re: Text on a curve
Post by mtylerfl »
springer668 wrote:
Mon May 18, 2020 9:26 pm
At Bookmark 5, the following video tutorial shows the procedure:
https://www.vectric.com/support/tutoria ... or_Drawing
springer668
Re: Text on a curve
ok, cut the circle, applied my text, all went well: but the video does not show how to re-unite the two 1/2 circle vectors. i tried 'join vectors' and everything else i could think of, but no luck. i eventually just deleted the two 1/2 circles and drew a new circle around the text, but that created some alignment problems. how do you re-unite the two 1/2 circles please. thanks?
Re: Text on a curve
Post by martin54 »
You shouldn't have had any problems re-joining the vectors, select them both right mouse click & select join/close selected vectors. You can also do it from the drop down menu under edit.
Another way would be to copy the circle before you cut it, cut the circle & do your text thing & then delete both half circles as you did when you couldn't join them. Now just go the the edit menu & select paste & you will get your original uncut circle back or at least a copy of it :lol: :lol: :lol:
SteveNelson46
Re: Text on a curve
Post by SteveNelson46 »
To make the clock you pictured in your 1st post you do not need to use "Align Text To A Curve". Use the procedure outlined by Gkas. The diameter of the array copy is determined by the original position of the first number or tic mark and the center of rotation that is entered in the "Circular Copy" tool dialogue box.
Here's a link to a short video (no sound).
newmexico
Model of CNC Machine: Shopbot
Re: Text on a curve
Post by newmexico »
scotttarnor
Model of CNC Machine: Piranha XL
Re: Text on a curve
Post by scotttarnor »
Thank You for the video Steve, I learned some new tricks !
Scott T
SteveNelson46
Re: Text on a curve
scotttarnor wrote:
Thu May 21, 2020 11:18 pm
You're welcome. Glad I could help.
Re: Text on a curve
Post by mtylerfl »
Good job, Steve!!
SteveNelson46
Re: Text on a curve
mtylerfl wrote:
Fri May 22, 2020 1:05 am
Good job, Steve!!
Thanks Michael.
