scaleing a project
blmac5
scaleing a project
Post by blmac5 »
I am making a sign for my S-I-L and I took a picture of the piece of wood she wants it on. I was going to import it
into my program and trace the outline shape of the board to make sure I get the lettering right and in the correct
position. I remember seeing a video tutorial on how to scale the project to match the dimensions of the piece, but
I don't remember where I seen it at. Any help or suggestions would be greatly appreciated.
Bobby
Louisiana
Re: scaleing a project
Post by mtylerfl »
Hi Bobby,
For something like this, I would probably just drag one of the corner handles to resize by eye until happy with how it looks in relation to your background Bitmap/photo.
eph210
Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Post by eph210 »
When I do natural edge boards, I clamp them down to the spoilboard on my Stinger and then use WinCNC's built in manual trace function.
I use the positioning laser on the Stinger to walk around the board and then enter the end and mid points of a series of arcs into WinCNC.
They are then saved as a DXF which I can import into Aspire and have the exact size and position of the board on the machine.
After having done over a hundred of them, I have got the process down and they don't take very long to do now.
The first one however, took a little bit to figure out.
If you have any questions about the process I will be happy to answer them.
Euan
M Queen
Model of CNC Machine: WinCNC Hybrid
Post by M Queen »
Euan
That's a great idea, Euan.
Mike Queen
Microsystems World CNC (WinCNC)
https://www.youtube.com/user/cncMike304
SteveNelson46
Post by SteveNelson46 »
I imported the pic from your post and sized it to the measurements. Then I used the line drawing tools to outline the shape. It took about 10 minutes. It's not perfect but, it should be good for carving. The graphic is on the bitmap layer (hidden).
Natural Edge.crv
(2.17 MiB) Downloaded 7 times
Jim_in_PA
Model of CNC Machine: Camaster Stinger II SR-44 (MacOS user)
Post by Jim_in_PA »
I draw a rectangle that represents the measured length and width of the irregular piece that I have photographed from above, import the photo and scale it to fit in the rectangle. That's sufficient for most of what I do.
scottp55
Post by scottp55 »
That's pretty much how I do it Jim.
I try to do it after it's jigged, and with a straight edge(90 degree angle even better for cropping)...
and then a Post-It so I don't forget exact size(me forget...Never:)
My problem is getting a straight shot with an SLR from the 'Chair :oops:
It's pretty darn close if measurements and pic are good.
"Go not where the path may lead;
Go instead where there is no path, and leave a Trail"
RWE
Post by TReischl »
As simple as doing a dimension on the tape measure then doing the simple math to calc the scale factor.
blmac5
Post by blmac5 »
Thanks for the comments , I appreciate them. Got the project sized and completed. S-I-L was well pleased with the sign, so I'm happy. Painted the lettering and used some mica power and CA glue for the inlay's.
