HI
I'm doing a little test using the 'allowance' and final last pass and I have set the last pass to reverse just to see how an edge will clean up. I have the options checked but the last pass doesn't reverse.
What am I doing wrong?
Profile cut not reversing on final pass
Re: Profile cut not reversing on final pass
I've never done it with a 0 allowance as you have set. If you set an allowance value then it works. I'm undecided if that's correct behaviour or not.
Hi Adrian
I shall give that a go tomorrow.
Peter
Peter
You were correct.
Cheers
Peter
Cheers
Peter
