Grill Handle
scotttarnor
Model of CNC Machine: Piranha LX
Grill Handle
Post by scotttarnor »
I thought I would experiment and try making a New handle for my Weber grill. I am missing something.
Why I am not cutting through both sides of the tool path?
I have attached a screen shot and the file I tried to make.
Thank You
Grill handle.crv
(32.5 KiB) Downloaded 12 times
Scott T
sharkcutup
Re: Grill Handle
Post by sharkcutup »
Lost as to what handle should look like! Do you have a photo or drawing of what the handle looks like?
Sharkcutup
Facebook: Hogan's CNC Crafts
www.hoganscnccrafts.com
V-Carve Pro 10.022
Re: Grill Handle
Post by highpockets »
Here are the setting I used.
I also decreased the stepover on the BN
scotttarnor
Re: Grill Handle
Thank You High Pockets !
I followed your changes entering them 1 at a time to try and understand how they changed the result.
I would have never found that 'Boundary Offset" effected the depth of the cut !
Thank You for your quick response ! Now I can go get some sleep and work on cutting this out tomorrow.
Scott T
scotttarnor
Re: Grill Handle
Sharkcutup, I am working on something like this photo. I hope to be able to carve a few friends names in them and give them as gifts, I have 2 friends that are hardcore Weber grillers.
Scott T
Re: Grill Handle
I think that's a great idea.....
BigC
Model of CNC Machine: Workbee
Re: Grill Handle
Post by BigC »
$49 for a freaking handle, somebody's getting burnt. 8)
Nice project though.
Regards
C
jay pieper
Model of CNC Machine: laguna swift 4x4
Re: Grill Handle
Post by jay pieper »
Now for only 3 easy payments of 19.95 I can and your name to the handle !!!!@!
scotttarnor
Re: Grill Handle
Another question, I have seen numerous video's on using the moulding tool path. I have not found any on creating the actual moulding profile. Does anyone have a favorite videos or guides they can share?
Thank You
Scott T
Re: Grill Handle
Post by TReischl »
Scott, a good place to look for profiles is a router bit catalog. There are some web sites that show the profiles and it is a simple matter to just grab the pic and use it to trace a profile you like.
Years ago I had a catalog of all sorts of victorian moldings but I gave it away. I am thinking Leo has it cause I gave him a ton of books when we moved out that area. Maybe not though.
Re: Grill Handle
Post by martin54 »
Just to add to what Ted said, some time ago I found profiles in PDF format & when imported it turned out they were already vectors, it was a couple of years ago so sorry I can't remember where they came from so you will have to do your own searching.
Re: Grill Handle
Post by martin54 »
BigC wrote:
Fri Apr 03, 2020 8:13 am
Regards
C
While that may seem expensive to you BigC & obviously you could make yourself one cheaper for your own use BUT could you make them much cheaper if you were making them as a Business & selling them?
I haven't looked into material costs & ovioully labour costs for something like this but once those are factored in what sometimes looks like a huge profit is actually quite minimal, not saying that is the case here obviously though :lol: :lol: :lol:
Re: Grill Handle
Post by TReischl »
Something tells me that a lot of those handles do not get sold. . . . .
scotttarnor
Re: Grill Handle
Well This project has been put on hold till I learn more about tool paths, I did a practice run and my Hobby Piranha CNC does not like the 1" plunge and cut of the moulding tool path. I tried slowing my plunge rate to 10" per minute it did not mind that, I slowed the feed rate to 30" per minute and the Piranha was still not like cutting that much material. It would take forever to cut at any slower rate.
Win some lose some.
Scott T
Re: Grill Handle
Post by TReischl »
Hmmm, pass the vectors over to someone with Aspire and have them create an stl for you?
