Encountered another problem I can't seem to figure out, so again I need to tap upon the vast knowledge of everyone here.
I'm working on an Easter Bunny tray, similar to Michael Tyler's Holiday Snowman tray. The problem I've run into is that when I run the vcarve tool path for the details, it also cuts the pocket even though I isolated the pocket and created it's own tool path. I looked at the Holiday Snowman but can't see how Michael cut just the pocket.
Currently, I'm making the tray out of a single one inch piece of stock, but I may change and do it in two pieces like the snowman.
The file I'm working on is attached. This is a working copy and still needs a lot of fine tuning.
As always, any advice is greatly appreciated.
Pocket Problem
- pd417
- Model of CNC Machine: NWA Piranha FX XL
Pocket Problem
- Bunny Tray_2.zip
- (1.02 MiB) Downloaded 48 times
- highpockets
Re: Pocket Problem
I'm only a novice
Delete this vector line maybe!
- sharkcutup
Re: Pocket Problem
With time you could transpose the bunny tray to a whole 3D Look.
Like This This is a bit rough but it gives you the idea of what it could look like with some time spent on it!
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- pd417
Re: Pocket Problem
John....your suggestion worked, thanks!
Sharkcutup....I really like your ideas and since our state imposed a self quarantine, I have a whole lot of time
to work on this project
How did you cut the bunny's face?
Once it's done, I'll post a pic in the gallery.
- sharkcutup
Re: Pocket Problem
Yes, it could be done with time and a little beefing up a bit (whiskers for example are only about .05 thick). Would possibly break up when carved.Sharkcutup....I really like your ideas and since our state imposed a self quarantine, I have a whole lot of time
Beefed up Whiskers and cleaned up some areas
It was carved using staged incremental pocketing of certain vectors. Think in increments of thickness .125" .25" .375" .5" .625" .75" .875" 1" (8 incremental pocketed layers of certain vectors in each as an example) It is using those various depths to provide an illusion of 3D.
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- pd417
Re: Pocket Problem
Thanks again!
- sharkcutup
Re: Pocket Problem
I am a little concerned about the Whiskers they may still need a little more beefing up!
I think I will carve one for self now that I have it detailed out!
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
