An Arc of certain degrees?
- Model of CNC Machine: Shapeoko XXL
Can anyone tell me how to create an Arc of exactly 240 degrees? Sorry, somewhat of a newbie! Any response is greatly appreciated! Thank you!
- SteveNelson46
Re: An Arc of certain degrees?
There may be an easier way than this that I am unaware of.
Draw a circle to the desired diameter and center it
Draw a horizontal line through the center of the circle a little longer than the diameter of the circle.
Copy and paste the line on top of itself
Rotate one of the copies 240 degrees and center it
Use the trim tool to cut away the unwanted portion of the circle
Delete the lines.
There is probably an easier way but this will work.
Delete the lines.
- highpockets
Steve has given you a very good way to do it.
Here's an alternative:
The Draw Arc tool can't create an arc greater than 180° as I'm sure you figured out. So, create two arcs 120° each and join them.
- mezalick
You could use the numeric input boxes for the polyline tool
1. Job setup 6” x 6”
2. XY location “Center”
3. Create 6” circle, Center in work space
4. Click on “Draw Line” Icon
5. Input as follows.
a. X=-3 Y=0 Click “Add”
b. X=0 Y=0 Click “Add”
c. Angle = -60 Length = 5” Click “Add”
6. Close window
7. Trim Vectors
Michael
6. Close window
7. Trim Vectors
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Thanks Guys, This is exactly what I needed, now I have several ways to do this. I'll have to try them all to see which I prefer!
You guys are great and I appreciate your time and details in responding!
- sharkcutup
2.) Draw a horizontal Line of 3.5" from center
3.) Highlight line by click on it
4.) Select Circular Copy
5.) X= length of horizontal line y= Leave alone
6.) Input rotation center x=0 y=0
7.) make sure box is checked "Rotate Copies"
8.) number of items = 2
9.) Set "Total Angle"= -240.0
10.) Select Copy
11.) Trim Vectors for your intended arc of 240 degrees
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
- mezalick
sharkcutup wrote: ↑Sat Mar 28, 2020 11:56 amARC 240 Degrees.png
1.) Draw a circle of 6"
10.) Select Copy
Sharkcutup
Very Nice ! A+
~M
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
I wonder if arc through 3 points could be used somehow...
