I was thinking about going with smooth stepped or the uccnc smooth stepped which one do most people use I am running Mach 3 now with Bob if I use uccnc I can use their software but in vcarve all the processors are mm I like inches how do you use uccnc in inches would like to find out some info on these before I make my mind up on which smooth stepped to buy
Roger
Uccnc wit vcarve
- gkas
Re: Uccnc wit vcarve
lose your punctuation keys?
You can use the Mach3 inch post processors with UCCNC.
look at ger21 website, he has post processors for Vectric software, think they were also posted on here a while ago if you do a search. I have been using the mm version since they were first posted. Also worth looking at the 2017 screenset if you are thinking of using UCCNC software.
http://www.thecncwoodworker.com/uccnc.html
