Hello, -sorry about my english- I hope you can understand ;o)
I will create a toolpath for a CNC plasma cutter in VCarve And there I will use a tangential start before the outline of the part.
in my attachement you can see my problem- the tartpoint of the square is correct- its out of the part but the start of the inner circle must be of the other side of my line- How I can change this?
Thank you, Ron
How I can change the direction of a tangential toolpath start?
- Model of CNC Machine: self made
Re: How I can change the direction of a tangential toolpath start?
Ron,
Are you using two toolpaths: one for the square and one for the circle? If so, try just one toolpath and select both the circle and square for it.
Steven
Steven
Oh wow
Vcarve can read my mind and knows what should be the result
THANK You!!!!!!!!!
THANK You!!!!!!!!!
