Hello all,
Another newb question. I've downloaded the Amana tool database and the bit I want to use is not listed. Is there a way to input the bit or am I stuck with only what is listed? The bit in question is the Amana straight plunge #45427. TIA.
My bit not listed in database, Can I add it?
- dealguy11
Re: My bit not listed in database, Can I add it?
Yes, of course you can add it. The tool type will be "end mill". Check the help file for how to add tools...it's pretty straightforward.
Steve Godding
- Xxray
Many users chose select then copy a similar tool, then you can just change the name and any parameters you want.
Doug
This is from the help files
https://docs.vectric.com/docs/V10.0/VCa ... 20Database
there is a video tutorial for the tool database if you check in your portal account under training,but not sure how linking to the video tutorials works with the new forum layout
