New tool database: Can't set an end mill to zero RPM
Mikehell
Model of CNC Machine: eBay special China 3040
Post by Mikehell »
So far I'm digging the new tool database. However, I can't figure out how to input my marker. I have this adapter thingamajig that holds a mini sharpie, so I can draw a grid on my spoilboard. If I set it to be an end mill (like in previous versions) it will not let me set to 0 RPM. For some reason, if I set it to a diamond drag bit, it won't let me choose the bit for a profile tool path.
Also, what but type do I use for a drag knife?
cusoak
Re: New tool database: Can't set an end mill to zero RPM
Post by cusoak »
Why do you care about router rpm,s if that is what you mean,I would not think you need to turn the router or spindle even on. I assume you did a file to create the grid ifso just set the tip of the marker to your bed lightly and run the program with the router
Jeff turned off
Mikehell
Post by Mikehell »
cusoak wrote:
Sat Mar 07, 2020 2:24 pm
Jeff turned off
Not all of us use a router. A spindle doesn't have an on/off switch.
So far, I've just modified my GCode and added an M05
Jim_in_PA
Model of CNC Machine: Camaster Stinger II SR-44 (MacOS user)
Post by Jim_in_PA »
You can use a modified post processor that disables turning on the spindle...that's what's often used for drag knives, etc., for the same reason you'd want to use it for a sharpie marker for drawing.
Post by Rcnewcomb »
Just specify it as a diamond drag bit. That allows the RPM to be set to zero, and you can specify the line width of your marker. No need for a custom post-processor.
10 fingers in, 10 fingers out
another good day in the shop
You can't use a diamond drag with a profile toolpath though.
Mikehell
Post by Mikehell »
Adrian wrote:
Sat Mar 07, 2020 7:07 pm
BINGO! that's the problem!
Post by mtylerfl »
Mikehell wrote:
Sat Mar 07, 2020 8:39 pm
Can't you use the Quick Engrave Toolpath set to Outline in order to draw with your pen? (with your zero rpm diamond drag tool selected, of course)
