I have been using these settings for my Amana insert V bits.
Anyone use these and do my settings look correct.
Thank You
Don
Question about V-Bit
- Makingtoothpicks
- Model of CNC Machine: Cncrouterparts CPR2448
- Makingtoothpicks
Re: Question about V-Bit
I got the setting that Amana has for Vectric tool Data base. Here is a screen shot of there settings
Well, the settings really do depend upon what you are cutting. The settings in either screen-shot may be correct for certain materials
I once engraved some text on a bee's wax slab that needed to be run at: 2,000 rpm and 10 inches/minute feed rate. Even then I suspect 2,000 was too fast. I wouldn't recommend those speeds for rock maple.
- Leo
The settings look "reasonable" - even to the conservative side.Makingtoothpicks wrote: ↑Wed Mar 04, 2020 9:32 pmI got the setting that Amana has for Vectric tool Data base. Here is a screen shot of there settings
If you put the number of flutes in the box asking for that, Vectric has been so kind as to calculate the chipload for you. I would gander a guess that .005 - .010 would be reasonable.
- Makingtoothpicks
Leo how do they get the D dimension .0313.
When I did my "D" dimension I measured across the cutting area.
Is the "D" dimension arbitrary. It is not the shank dimension.
Don
Don
That diameter does not make sense unless the V bit is only 1/32" widehow do they get the D dimension .0313.
