Hey...firstly let me apologize as my lingo is not up to par. Recently, my x axis is no longer homing to the right position after cuts....between 1/2 inch and up to 6. When I do the inner cuts of letters they are way off from my outer cuts, making all my cuts useless. I have been unable to pinpoint how to correct this issue, has this ever happened to anyone and what have you done to fix?
Thanks in advance.
Robyn
X axis no longer aligned
- Leo
Re: X axis no longer aligned
There are soooooo many different machines on the market it is near impossible to answer a specific question on a specific machine.
Have you gone back to your machine manufacturer to ask the question?
Not knowing how robust your machine is, it is extremely difficult to answer the question.
You will get tons of guesses for sure.
What RPMs and feedrates are you running? What is your depth of cut? What material are you cutting? What size cutter? How many flutes? What spindle do you have?
- mezalick
Robyn,
It sounds like a machine problem.
It could have been caused by too aggressive of toolpath strategy, for example, too fast for the speed, too deep for the cutting, etc.
This would cause you machine to loos steps, or better said, it's place in the universe.
Or, it could be that the motors that run you X,Y & Z axis are failing, along with the steppers / servos.
It would be helpful to know what you have the software set to , Feeds and Speeds and Pass depth with the size of bit you're using, so we eliminate that.
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- jfederer
- Model of CNC Machine: CanCam D23M
Robyn,
I also have a D23M. You should contact CanCam and explain the problem. I had a similar but not nearly as bad a problem with the Z axis mis-aligning by about 1mm on critical cuts. They had me reprogram some settings, and the problem vanished. I think they increased the step instruction delay or something like that. In any case, it's definitely a machine problem. I've found Tom and the folks at CanCam to be very responsive.
Joe Federer
www.federer.ca
www.federer.ca
