New to V-Carve Pro
lakemfg
Model of CNC Machine: shopbot
New to V-Carve Pro
Post by lakemfg »
Hi, I just purchased v-carve pro software and am having a hard time figuring out how to get the fonts to become smooth? I am familiar with g-code programming and am stumped as to why when I save the tool paths for say a letter "O" that it saves it with a g-code of G1 and not G2or a G3.....???
I have tried....watching a bunch of videos, changing nodes to curves, used different fonts, different post processors but haven't found anything that works. My gantry is solid and have done perfect circles (machine cost around $10,000/$20,000 when new)....just doesn't do fonts smooth...….!!!!
There has to be a simple answer!!! Can somebody please, please help me before I go crazy.
scottp55
Re: New to V-Carve Pro
Post by scottp55 »
How big are fonts you're trying it on? (Less than .25" height and you get into a small different world on settings)
Can you show an example cut in your material please?
Which machine is it? I take it you bought used? (I have ballscrew, but Pinion gears are considered consumables...check for slop?)
If preview is smooth in Vectric...PP problem(?)(do a UR for Your machine also?)...then it's a machine problem, and a pic can help us.
GMH
All depends on how the font is constructed. If it's made of arcs and you're using a post processor that supports arcs then it will have G2 G3 commands in the code. Otherwise it will be output as short moves.
Smoothness should be nothing to do with the output though. My machine cuts letters comprised of bezier curves identically to ones comprised of arcs.
Have you zoomed right into the letters while in node edit mode? In my experience a lot of fonts look smooth to the eye but when you get in close the nodes are all over the place. No problem for screen display on web pages and type etc but no good for a CNC cut. You can use the "Fit curves to selected vectors" tool to smooth out the lines and/or convert to arcs etc.
Post by TReischl »
Just so you know. . . . a cnc machine operating in X,Y,Z cannot cut a true arc. A G2/G3 move is broken down internally into extremely small straight line segments. The only place you can cut a true circle on a cnc machine is on a rotary axis.
Can you post a pic of one of the fonts you are having an issue with showing the straight line segments? It will be helpful if you can tell us the font name, too.
wmgeorge
Model of CNC Machine: Fine Line Automation Saturn 2 4x4 ESS
Post by wmgeorge »
TReischl wrote:
Sun Feb 16, 2020 2:47 pm
Even if my Mach4 Post processor says arcs and curves?
IslaWW
Post by IslaWW »
wmgeorge wrote:
Thu Feb 20, 2020 6:45 pm
In reality G2/G3 (Gcode arc) commands, although relevant, are a bit of a holdover from yesteryear. They simply reduce the lines of code required to cut an arc in a given file.
All circular or curved cuts are performed by the machine executing a series of very short straight segments. These segments are either generated by the post processor (no arc type postP's) or in the machine controller itself (arc type postP's). In any case a cnc machine is incapable of making a curved move. They ONLY make straight point to point moves.
The difference to the user comes in when the controller does not handle the externally created segments as well as those created internally. In most cases using modern controllers there is no perceivable difference in speed or quality unless the difference in segment length is noticeable. This is a product of better controllers with more lookahead. 2000 lines being the current norm for quality controllers.
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
Post by TReischl »
Exactly what Gary said.
Here is my take on the situation. Unless you are running an antique control there is every reason to NOT get hung up on arcs thinking they will be the smoothest curves you can cut. Bezier and other mathematically defined curves are much more flexible (pun intended) than circular arcs. A good example is automobile body work. You would have a hard time finding a circular arc since they are not designed with arcs to begin with.
Like pretty much everyone else I thought that two arcs tangent to each other was the smoothest transition possible. Turns out that is not the case. But it is a long winded subject that I only partially understand.
