dovetails using CNC
dbreckon
Model of CNC Machine: Can Cam
dovetails using CNC
Post by dbreckon »
Has anyone found a way to cut dovetails using their CNC with V Carve Pro 10
sharkcutup
Re: dovetails using CNC
Post by sharkcutup »
With 9.5 V-Carve Pro I have using the Dovetail Creator Gadget
And there is another Dovetail Gadget where you can cut the end of boards off the end of the CNC table too! (Have not tried this one besides I do not have the off the table fixturing for it)
Have not had the luxury yet to upgrade to V10 yet but I do have the trial version just to keep up with things/progress!
Sharkcutup
Facebook: Hogan's CNC Crafts
www.hoganscnccrafts.com
V-Carve Pro 10.019
dbreckon wrote:Has anyone found a way to cut dovetails using their CNC with V Carve Pro 10
http://gadgets.vectric.com/V10/dovetail.html
sharkcutup
Thank You Adrian
I forgot that "Big" detail in post a link! ARRRRGH!
Sharkcutup
V-Carve Pro 10.019
Mike-S
Post by Mike-S »
You don't have to limit yourself to regular dovetails.
Holzarbeiter
Model of CNC Machine: Camaster Stinger SR24
Post by Holzarbeiter »
Wow, Mike, those are beautiful joints! You made them using Aspire/Vcarve?
I also like the finger joint cabinet in the pic.....would love to see the whole thing!
Joe
scotttarnor
Model of CNC Machine: Pirnha LX
Post by scotttarnor »
Mike those are awesome!
Scott T
Post by Rcnewcomb »
10 fingers in, 10 fingers out
another good day in the shop
Mike-S
Post by Mike-S »
Thanks, yes they were done in Aspire.
BillK
Model of CNC Machine: CNC Shark Pro Plus
Post by BillK »
https://forum.vectric.com/viewtopic.php ... be#p133032
In the third comment, you’ll see a pdf of how I did mine. Works really well.
BillK
https://www.facebook.com/CarvingsByKurtz
4DThinker
Post by 4DThinker »
Conventional dovetail joints aren't outrageously hard to make toolpaths for if you have some basic drafting skills and a way to clamp each half of the joint vertically. You need to know the specifics of the bit you'll be using (blade angle and widths at bottom and the depth of the joint.). I typically cut dovetails for my students once or thrice each semester. All types except for the very narrow hand cut versions that no router bit can produce.
4D
jTr
Model of CNC Machine: Shopbot PRSAlpha9660
Post by jTr »
Where can I find the gadget for creating dovetails off the end of the table?
Jeff
sharkcutup
V-Carve Pro 10.019
bravesoul1950
Post by bravesoul1950 »
Mike-S wrote:
Wed Feb 12, 2020 1:28 am
Mike,
I really like the first picture you posted of your joints, would you be willing to share the file?
Joe
Mike-S
Post by Mike-S »
Sure. IIRC I left 1/100" space for fitting and glue.
BearDoveTails2.dxf
(672.89 KiB) Downloaded 52 times
