Circle resizer Gadget
ezurick
Re: Circle resizer Gadget
Post by ezurick »
rtibbs2018 wrote:Oh, I think there is room for all of us. Don’t have to read it if you’re not interested
The point is that there is a forum just for the subject. I wasn't trying to be a dick. Sure I can pass from reading. Just as you could have passed from reading my comment and posting your comment.
Mark's Wood Chips
Model of CNC Machine: ShopSabre 23 with Rotary
Post by Mark's Wood Chips »
Adrian wrote:The advantage of the gadget is it's a one step process whereas with the offset you have to use the vector selector first to select which circles you want. Of course if you're doing all of them then they're as good as each other.
I get this dialog box if I don't pre-select the circles even though the gadget seems to allow selection afterwards. Any idea why this is happening?
Mark
Circle Resize Dialog
sharkcutup
Post by sharkcutup »
The script is looking for circles to be resized therefore if there are no circles selected/highlighted the requester pop-up comes into view. It is just letting you know that the next time you run the gadget to be sure to select the circles first.
Sharkcutup
Facebook: Hogan's CNC Crafts
www.hoganscnccrafts.com
V-Carve Pro 10.019
Mark's Wood Chips
sharkcutup wrote:The script is looking for circles to be resized therefore if there are no circles selected/highlighted the requester pop-up comes into view. It is just letting you know that the next time you run the gadget to be sure to select the circles first.
Sharkcutup
I get that but it doesn't answer my original question. Adrian indicated that using the circle gadget was a one step process so pre-selection was unnecessary.
Mark
Post by mtylerfl »
Hi Mark,
You DO have to select the circles first. Are you entering the menu values so that the circles fall within the suitable setting/perimeters?
Sharkcutup
Mark
It's one step in that you don't need to run two commands to get the selection. With both methods you have to have a selection to start. With the gadget you can press Ctrl-A to select all vectors and it will then only operate on the ones that meet your parameters. With the offset method you would need to select just the circles you wanted with the vector selector unless you had pre-assigned to layers etc. Of course with the gadget you can only resize a set diameter circle whereas with the offset method you can enlarge many different diameter circles by a fixed amount. Each method has it's advantages and disadvantages.
sharkcutup
There is a caution note with use to the gadget I will mention here!
Once you use the gadget you cannot undo (Ctrl-z) the new sizes, but you can re-use the gadget to change them back or to another size.
With the Offset you can use undo (Ctrl-z)
Sharkcutup
V-Carve Pro 10.019
Mark's Wood Chips
OK, I finally get how it works thanks to everyone's help. Of interest, after successfully running the gadget on a test file, I closed out and did not receive a warning to save because the file had changed. Maybe that's a characteristic of gadgets in general?
Mark
Not always as it depends on exactly what the gadget has done. There is no undo though as Sharkcutup has pointed out. That's something I would dearly love gadgets to have as I use a lot of them every day and I get caught out a few times when I make a simple mistake.
