DXF missing lines on import to vcarve
David2180
Model of CNC Machine: Pro408 shopsabre
Post by David2180 »
I'm trying to import the current file to cut into vcarve pro but it doesn't come in with all the lines, what am I doing wrong here?
file import not working.dxf
(168.55 KiB) Downloaded 17 times
SteveNelson46
Re: DXF missing lines on import to vcarve
Post by SteveNelson46 »
It works for me. You need to zoom way, way out. After importing, press F9 to center the import.
gkas
Post by gkas »
Interesting..... :( If I double-click on the file from the file manager, it opens Aspire, and it seems to import correctly. If I import dxf vector into an open file and it's missing lots of parts. :?
SteveNelson46
Gerry.
I don't see any parts missing. I opened the file with Aspire then imported the same file. Both are identical.
David2180
Post by David2180 »
Steve the file you have screen shot is missing the parts I'm referring too, not sure why though,there are more lines in the actual drawing than your screen shot shows.
David2180
Post by David2180 »
attached is the correct file as it should look
It's importing differently between V9 and V10. I expect gkas has different versions loading on a double click.
With V9 it imports fine with all lines, but with V10 a lot of the data is missing. Interestingly I tried to load it another program and it said it wasn't a valid DXF/DWG file so I'd guess something went wrong with the conversion presumably from Sketchup going by the over thread.
SteveNelson46
Well, I opened the file in Corel Draw and, lo and behold, it was different. There are many versions of .dxf files so I'm not sure what is going on. Aspire 10 does open or import it (sort of).
Last edited by SteveNelson46 on Sat Feb 08, 2020 5:43 pm, edited 2 times in total.
David2180
Post by David2180 »
your right it does good in vcarve 9 but not in version 10
gkas
Post by gkas »
Adrian wrote:It's importing differently between V9 and V10. I expect gkas has different versions loading on a double click.
You are correct.... I forgot I even had 9.5 installed. :oops: I was 'only' leaving it in until I was sure 10 was OK.
gregk
Vectric Staff
Model of CNC Machine: None
Post by gregk »
Thanks for reporting this issue and apologies for the inconvenience. We will investigate.
Greg K
gregk
Vectric Staff
Post by gregk »
This issue will be fixed in the next patch.
Greg K
