When I load a DXF file it's to big
I have a DXF file I've been trying to load that I can't to be the right size. I've tried just opening and creating a file and then importing it and have had no joy with it. If someone would give me a hand with this I and a few friends would really appreciate it. I attached the file if you'd to take a shot at it.
- springer.dxf
- (130.75 KiB) Downloaded 69 times
Re: When I load a DXF file it's to big
What length and width do you think the material rectangles should be? They appear to be 800 by 600 units. This suggests millimetres. If that’s so are you creating a VCarve file that use mm as the input units?
Re: When I load a DXF file it's too big
It is also offset to the upper right.
After you get it centered (Edit/Selection/Select All Vectors then press <F9>) you will want to run the Vector Validator on the drawing to identify the vectors that aren't properly joined.
Create a job that is at least 1610mm wide and 600mm tall and whatever thickness is appropriate for your material. Import the DXF file, press Ctrl-A to select all vectors, press the F9 key to centre them in the material. You can now go back to the Job Setup dialog and change to inches if you desire.
- SteveNelson46
As an alternative you can open it with V-Carve/Aspire and scale the drawing with the job size by putting a check mark in the "Scale Design With Job Size" check box in the Job Setup. Works with V-10. Not sure about previous versions.
