unequal radii
Peteg
Model of CNC Machine: HomeMade
unequal radii
Post by Peteg »
All the corners of this cutout are programmed with the same radius, yet when cut, they clearly aren't. Any ideas as to why this could be happening?
Best
Peter
Leo
Re: unequal radii
Post by Leo »
There are many ways to answer the question. Lots of unknowns here.
It might be:
Machine flex
Accell - decell
cutter diameter
workpiece moving
feed - speed
many other reasons
www.leosworkshop.com
WNC_Ed
Re: unequal radii
Post by WNC_Ed »
Always easier to help if you can post the file.
Looks like a diagonal mirror effect.
Maker of sawdust
Re: unequal radii
Post by TReischl »
Grab your homemade machine's spindle and give it a pull while you have an indicator touching it. Not dissing your homemade machine, so is mine.
There are so many things as someone already mentioned it is hard to tell, another is how CV is set in the control software.
One thing I can guarantee you is that if you drew those arcs all the same size then you have a machine issue.
Are these the first cuts you have made on your machine?
Re: unequal radii
Post by TReischl »
WNC_Ed wrote:Always easier to help if you can post the file.
Hey Ed,
I have been around for more than 20 minutes and have never heard of the "diagonal mirror effect"? A new one to me, care to enlighten me?
(In NC we do not say hello to each other, we say "Hey" so I am not being rude, LOL)
Re: unequal radii
Post by highpockets »
It maybe the picture, but it does look like some mirroring and rotation effect going on...
Peteg
Re: unequal radii
Post by Peteg »
Humbucker.crv
(163.5 KiB) Downloaded 16 times
Hi
Thanks for the replies.
Work piece didn't move, but I will check the you other suggestions.
I am intrigued by the diagonal mirror effect, please explain.
Cheers
Peter
Re: unequal radii
Post by TReischl »
That sort of thing can be caused by excessive backlash, curious as to what your method of motion is?
Re: unequal radii
Post by Rcnewcomb »
The preview is fine and the vectors are symetrical. The stepover on your 12mm bit is large -- I tend to keep it under 50% -- but I didn't see any problem caused by that.
Check your control software for constant velocity setting.
You also may be dealing with machine flex.
Does the shape change if you use Conventional rather than climb?
What about Raster vs. offset?
Each of those will load the machine differently.
10 fingers in, 10 fingers out
another good day in the shop
Peteg
Re: unequal radii
Post by Peteg »
Hi
Thanks for all the replies. I'm going to try a raster cut tomorrow - it's not far off midnight here in England, if I had no neighbours I'd do it tonight :D
I don't know if this is relevant, but I had this problem before I started using Vcarve; I was trying to learn G code and was programming by hand. I cured it by including a dwell of about .2 seconds before a change in X, Y direction.
Cheers
Peter
Re: unequal radii
Post by Rcnewcomb »
Peter,
What are you running for a control system? Mach 3/4? UCCNC? LinuxCNC? etc.?
Re: unequal radii
Post by TReischl »
Peteg wrote:Hi
Cheers
Peter
Uh oh, sounds like you have some serious machine flex. I have no clue if a dwell would solve a constant velocity issue????? Never ran into that.
If the machine cannot do that profile cut you should not try to solve the issue by going to a raster cut. The problem needs to be addressed because you cannot run the machine by raster cutting everything, that will drive you bonkers after a while.
Re: unequal radii
If you can you should slow the rpms way down as well. At those very slow feed rates your chipload is way off for MDF. You're going to be dulling the bit extremely quickly which is only going to exaggerate your issues as the tool will be pushing more than it's cutting.
Peteg
Re: unequal radii
Post by Peteg »
Hi
Thanks again for all the replies. I am running Mach 3, and it appears to be an acceleration/deceleration issue with a small amount of flex in the Y axis.
I have made some adjustments in the motor tuning page of Mach 3, and the results are much better. The attached file was a conventional cut with an 11.1 mm clearance and 6.3 mm final pass. The apparent distortion is due to camera angle; everything is within the accuracy I am happy with and can only get better.
Cheers
Peter
I am new to this (as is obvious) and learning all the time.
sharkcutup
Re: unequal radii
Post by sharkcutup »
It is awesome to see that you have the problem solved. Sometimes here on this forum you do not always hear or see about the problem being solved.
Much better looking carving!!! :)
Sharkcutup
Facebook: Hogan's CNC Crafts
www.hoganscnccrafts.com
V-Carve Pro 10.019
