Rotary job going wonky
rhammans
Model of CNC Machine: Homebuilt Gatton
Post by rhammans »
I'm trying to duplicate some elk calls and from reading the forum, it appeared that using a molding toolpath would be the way to go. So after some tests that had different things go wrong that I figured out. I was ready for a final test and thought I had accounted for everything. But obviously not. You will see from the screenshot, that looks like what I want, and according to my drawing above, it has the right dimensions. But the first cut in the finishing toolpath, dove to a diameter of .300, the smallest diameter should have been .84. I'll post everything and maybe someone can see what I did. Thanks in Advance
Rick Hammans
screenshot of 2d and 3d preview
First cut Finish pass
CRV file https://www.dropbox.com/s/4c5s6ocq4zthl ... e.crv?dl=0
Clearing toolpath, .5 Ballnose end mill https://www.dropbox.com/s/pwgugm4c6lgn3 ... 0.txt?dl=0
Finishing toolpath .125 ballnose endmill https://www.dropbox.com/s/llub64qe4cqqx ... n.txt?dl=0
Rick Hammans
Loveland, Colorado
Re: Rotary job going wonky
Post by Rcnewcomb »
The smallest Z I could find in your finishing toolpath file was a RADIUS of Z0.4097 which is a diameter of 0.8194. This was starting at line N16440.
The file starts out with a rapid move to Z0.93 (=diameter of 1.86) and then a plunge to Z0.4174 (=diameter 0.8348)
Code: Select all
N220 G00 X5.5000 A0.0000 Z0.9300
N230 G1 X5.5000 A0.0000 Z0.4174 F20.0
I did notice your feed rate on the 1/8" ballnose was an astounding 20,000 IPM with a plunge rate of only 20 IPM. You may want to change the feed rate to something much smaller. I tend to keep my feed and plunge rates similar. For example, both at 180 IPM
10 fingers in, 10 fingers out
another good day in the shop
rhammans
Post by rhammans »
thanks for looking at it, I really appreciate it. As for the speed, the darn zeros. I wanted 200 ipm, not 2000. I guess I'll straighten out those numbers and try again.
Rick
Rick Hammans
Loveland, Colorado
