I used to have Job Dimensions showing in the lower left hand corner of VCarve Desktop. One of the last version I upgraded to made it go away. Is there a way to turn that back on again? I am on version 10.0.18.
Job Dimensions Missing
Re: Job Dimensions Missing
What screen resolution are you running? If you have the common drawing tools display checked you can turn that off to free up some space to get that section back. There's only so much room available so if you're running at a low resolution or a custom font size etc there won't be room to display that info as well as all the tools.
- Model of CNC Machine: Axiom Basic
1920 x 1080. There is plenty of room down there, just not being displayed.
- Aussie
- Model of CNC Machine: Robotics Model 8
Lower the percentagebbowers12 wrote:1920 x 1080. There is plenty of room down there, just not being displayed.
Ron
Crafers Crafts
Crafers Crafts
- highpockets
If "Show common tools on drawing tab" is checked, uncheck it and restart VCP.
- Model of CNC Machine: Home built cnc router using Masso G3.
Try dragging your windows task bar to the side of the screen instead of running it along the bottom, which is the default location.
Check your text size settings in Windows. If you're running at anything higher than 100% text scaling you won't see the job dimensions at that resolution. I run that resolution with 100% font scaling and all the common alignment tools displayed and I can see it.bbowers12 wrote:1920 x 1080. There is plenty of room down there, just not being displayed.
Show Common Tools was the fix for this, thanks
- highpockets
Vectric is aware of the issue, I'm sure a fix will be included in a future update...
