Roman Ogee Query
BigC
Model of CNC Machine: Workbee
Roman Ogee Query
Post by BigC »
It has become increasingly aware to me that a Roman Ogee bit (along with some other conventional bits) would be of some benefit for my hobbyist router.
Rather than doing it separately as pieces may be small
Can I use them? and how does one go about setting one up for tooling and XYZ positioning.
Maybe the same effect can be achieved by different means without a definitive ogee bit
https://www.rockler.com/classical-roman ... -32-radius
Forum advice appreciated
Regards
C
ozymax
Re: Roman Ogee Query
Post by ozymax »
You can create a form tool for the Ogee bit and carve away.
You will find how to do that in this video.
https://www.youtube.com/watch?v=k3hTPrqlVbE
The form tool part starts a little past the half way point in the video.
This video is more to up to date and uses V10 - https://www.vectric.com/support/tutoria ... _Toolpaths
