Diamond drag Bit recommendations
Aussie
Model of CNC Machine: Axiom AR6 Pro
Post by Aussie »
Hi All,
Would like to make some Edge lit LED Signs - What is your recommendation for spring loaded bits ? 60, 90, 120 deg ? Brand etc
Thank you
Ron
gkas
Re: Diamond drag Bit recommendations
Post by gkas »
I just used some spring loaded cheapo diamond drag bits on eBay. I think I paid $20-30 USD for them. I used mostly 90°. They came out pretty good. Turn your spindle off.
crv file https://drive.google.com/file/d/12W-6QM ... sp=sharing
Aussie
Post by Aussie »
gkas wrote:I just used some spring loaded cheapo diamond drag bits on eBay. I think I paid $20-30 USD for them. I used mostly 90°. They came out pretty good. Turn your spindle off.
Ok Thanks.
Did you use the engraving tool path ? if so what Pressure/Depth ?
gkas
Post by gkas »
Check the crv file I uploaded to Google Drive. The link is in the text.
FixitMike
Post by FixitMike »
I ran some tests of my diamond drag bit at different pressures. There was very little difference that I could see. So now I run it at .06", which is more than enough to allow for variations in the material thickness.
Aussie
Post by Aussie »
Thank you for the replies. A couple of questions.
When setting the Z 0 with a spring loaded drag bit... do you compress the bit and then set Z0
What do you consider the maximum vertical height that will be illuminated.
Here is my first attempt.
FixitMike
Post by FixitMike »
You set the Z 0 with the diamond just touching the reference surface. The pressure setting will cause the bit to be compressed that much when it is marking the material.
