Font Selection
GeneR.
Model of CNC Machine: Stinger
Font Selection
Post by GeneR. »
I have a question about the new fonts in V10. When ever I go to Create Text I find about 13 @fonts at the front of the list. My question is how can I put them at the back of the list ? Or should I just delete them?
Thanking you in advance.....
Re: Font Selection
The @ fonts aren't new. They've always been there. They are the Microsoft vertical fonts that are standard with Windows.
Also V10 has a new feature that puts your most often used fonts at the top of the list. If you want to disable it you need to enter 0 into the Recent Font List Size setting in the General Options section of Options which can be found on the Edit menu. That won't be what you're seeing but worth knowing perhaps.
GeneR.
Re: Font Selection
Post by GeneR. »
Thanks Adrian I appreciate the answer.
Jan.vanderlinden
Model of CNC Machine: Xcarve
Re: Font Selection
Post by Jan.vanderlinden »
Adrian,
Is there a way to get rid of them altogether?
Re: Font Selection
Post by martin54 »
They are in the windows font folder, Vectric software uses the windows installed fonts, not sure if you would be able to delete them from the windows font folder, I would check that is not going to cause problems with any other system or other programs you have installed before deleting any fonts in the windows font folder :lol: :lol:
