Hi
I am trying to create a molding 1 1/4 width X 5 1/2 height with beveled edge all way around using a V bit but leaving some thickness around not beveling all way .
can not find any training online showing how to do this.
i tried to use molding tool path but it gets so confusing when highlighting the inside 2 lines ( red color)
thank you in advance.
Bevel edge
- Model of CNC Machine: Omnitech 4X8 with 8 tool
Bevel edge
- Bevel molding.crv
- (17 KiB) Downloaded 51 times
- dealguy11
Re: Bevel edge
1. To use a v-bit, use a profile toolpath, cutting on the outside vector, setting the cut depth to whatever you want the depth to be. This may leave a little shelf on the edge if your v-bit isn't really sharp, so as an alternative you can offset the outside vector a small fraction of an inch and use that vector instead to leave a nice edge on the bevel.
2. To use a moulding toolpath, you will need to use one of the red vectors in your file, and also create a sweep vector with the profile of the bevel. I've attached a file with an example. I replaced both of your red vectors with a vector offset inwards by .25", and created a sweep vector. Note the little tail on the outside of the sweep vector that forces the bit to the end of the profile.
- Bevel molding v2.crv
- (46.5 KiB) Downloaded 73 times
- SteveNelson46
Re: Bevel edge
Something like this? Green nodes are the start points.
- Bevel molding.crv
- (44 KiB) Downloaded 51 times
Re: Bevel edge
For a simple bevel as this, I use a table saw. For me, it's much faster. Sometimes the cnc isn't the best suited tool for the job.
- SteveNelson46
Re: Bevel edge
Me too. I guess it would depend on where it's located in the carving.Samson wrote:For a simple bevel as this, I use a table saw. For me, it's much faster. Sometimes the cnc isn't the best suited tool for the job.
