corners
- Model of CNC Machine: SHAPEOKO XXL
corners
I waited for the update for version 10, but I'm still having problems when trying to change the radiused on external and internal when making squares. No matter what I do the corners remain square. Also can't seem to get the tools to merge? It was suggested that the file may be corrupt? Anyone else have this issue?
- SteveNelson46
Re: corners
Not sure about what you mean by "can't seem to get the tools to merge". Open a new file and see if it works there.
Last edited by SteveNelson46 on Mon Sep 23, 2019 5:26 pm, edited 2 times in total.
Re: corners
Can you attach the file you're having problems with? I very much doubt it's a corrupted file.
How are you doing the radiuses and what do you mean by merging tools? Do you mean merging toolpaths?
Re: corners
Not sure what you expected the difference to be between 9.5 & 10. You should have just asked straight away if your having problems
As Adrian has said attatching the file will help, there is more than one way to round the corners on a square, have you tried different methods?
- highpockets
Re: corners
Have you tried this?
Are you talking about saving multiple toolpaths in one file?
Re: corners
Now I'm really confused, let me go back to the problems and see if I can be more clear. Thanks
- highpockets
Re: corners
Pictures or better yet the file you're having problems with helps a lot.... Other wise everyone spends a lot of time guessing...
Re: corners
My mistake. (another one)
