Help
- scottp55
Re: Help
Need a LITTLE more info on the problem than THAT Woody:)
R.N.
R.N.
- scottp55
Re: Help
Hmmm......Seems to be working for me Woody...at least for these two with the setting shown in the second one.
Oh....Irfanview is a free basic photo editor.
R.N.
R.N.
- sharkcutup
Re: Help
I wonder if there is a limit to the amount of files uploaded? I do know they are stored in your user control panel under >front page>Manage Attachments. You are able to view them and delete them as desired. You may want to try to delete some of the older ones then try to add a new one again in the post you are not having any uploading success in.
Just a refresher here and for any newbies out there:
Uploading images you must click choose file first and select a file from your computer you wish to upload. Then Click add and it will upload to the forums memory. Then you click where you want the file to appear in your thread message. Then click the button below which says Place inline to add it to your threaded message.
Just some Thoughts!
Sharkcutup
Just some Thoughts!
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
- highpockets
Re: Help
Seems to be working fine.
You might try using a image editor app to reduce the size and try again.
Re: Help
try reducing the size a bit more, I know the blurb says max size 2mb but for some reason it will refuse jpeg images that are smaller than that sometimes. Often for me just making then a little smaller is enough for them to upload
So I wasn't really close with my other post then
- scottp55
Re: Help
PRETTY piece Dave!!!
Yep...when I have a "Portrait" orientation.....I have to use the next default resolution down in my image software on the forum.
R.N.
R.N.
- scottp55
Re: Help
Certainly looks good to me!!
Nice job!!
Nice job!!
R.N.
R.N.
