Ngoc Lu
Does anyone have a vector image of this?
I have a friend asking for this image.
Leo
Ngoc Lu
ngoc lu
Leo,
I just G00gled it and found the pattern...http://www.google.com/search?hl=en&q=ngoc+lu
save the image as a bitmap
open vcarve, create new
import bitmap
bitmap trace...your done.
the pattern is huge
good luck
i'll try and attach an image
import bitmap
the pattern is huge
good luck
- Leo
which image
I see a list of googgle stuff.
I have googled it before.
I have the wikipedia image but it is really low rezolution and does not trace well at all. I would need to almost redraw the entire thing. Maybe that is what i need to do.
Which image did you see that was soo large?
- Leo
Thank you - but
I have that same image. I downloaded it from Wikipedia.
That IS the image I am looking for.
The resolution is too low and the details are too fine - to get a decent vector trace on it.
The pixels are too coarse. Resizing it does not help.
Sooo - this is the image - but I need a high resolution image.
Either that - or someone can help me to get a decent vector trace on it.
low resultion?
Hello,
1000x1000 is a realy High Resolution.
What size are you coing to carve it later.
If you projet is smaler them 1m x 1m (100cm x 100cm) I am sure you will not be able to see them anyway.
I vectorized it and this is the result.
That is ok, for me =)
Since the small details cant be carved that good anyway.
Have a nice day, Frank
You do not like my bad spelling?
Come and write in a "German-Forum".
- Leo
high rez
I think I am trying to do something that can't be done.
I "was" trying to get all the fine details in there too.
When I did the vector trace - I did not get the detail that you got.
I will try again.
I will try again.
Inkscape
Hello,
I used INKSCAPE to vectorise the Picture.
Sometimes better them the Vector tool from VCarve.
