2d profile toolpath Problem
Mike Bordner
Model of CNC Machine: Shopsabre 23
Post by Mike Bordner »
Hello,
I have a simple 2d sketch that resists an outside tool path, inside tool path calculates properly.
The error is "no toolpath generated for current parameters.
Suggestions:
Thank You
Hermie
Model of CNC Machine: custom
Re: 2d profile toolpath Problem
Post by Hermie »
Looks like you have wiggle at the top center, that could mean it has a loop there that the cutter won’t fit into, zoom in and have a look.
You could also try the Vector Validator tool to report any problems with the vectors if you can't spot it by zooming in. Sometimes the overlapping nodes can be so close that they are hard to spot even when zoomed in.
