I'm playing with the trial version of pro and testing the 'Create Job Sheet' function. I have a test case where I have a number of tool paths created but want to select only two of those tool paths to include in the job. This is normal for me as I have multiple box designs in one file and select multiple tool paths from a larger list when I run the job.
Whatever I do with the Create Job Sheet, it lists all the tool paths and not the one's I selected (with the checks). Is it possible to do what I'm looking for? It would be useful for me to document the multiple combinations of tool paths I need to run to create a given box in a Job Sheet.
Create Job Sheet use case
Gary Mitchell
Kentucky, USA
Kentucky, USA
Re: Create Job Sheet use case
The Create Job sheet reports the whole job which includes all toolpaths. To get it to do only the selected (visible) toolpaths you would need to create a custom version of the gadget or send a request to Vectric to see if they could change it for a future version.
- Vectric Staff
- Model of CNC Machine: 6040 Desktop CNC
Hi there, I can certainly see the benefits in this situation, I believe at the moment there is not a way to customise the gadget to check to see if a toolpath is selected, so this would need to be updated within the main software.
I shall add this to list of revisions for the job setup sheet.
Many thanks for your feedback.
Sean
Sean
