Hello,
I 'm trying to run a toolpath around the outside vector of the attached file and and it keeps coming up that the tool won't fit in the area selected. I can run it on the vector and it works fine. I'm sure it is something very simple I'm missing. Any help would greatly be appreciated.
Mike
Toolpath help
Toolpath help
- question.crv
- (4.5 KiB) Downloaded 117 times
Hi Mike,
The vector is 'open' which shouldn't be a problem as VCarve Pro 4.6 can Profile around the Outside / Inside of open shapes. But in your design the Start and End nodes are overlapping as shown in the image below.
Node Edit > N
Drag one of the nodes on top of the other and the vector will snap closed.
I hope this helps,
Tony
Node Edit > N
I hope this helps,
Tony
