Blood/Juice Groove in Cutting Board
- WaltS
- Model of CNC Machine: ShopBot 2418 - Spindle - ScottP Spoilbrd
I need to put a blood groove around the inside perimeter of a cutting board. I want it to be 3/8" wide by 3/8" deep, rounded from side to side like a bowl (not just straight sides with a rounded bottom), and with rounded corners. I want to use a 1/4" ball nose, which I have. At first it sounded easy, but now that I think about it not so sure where to start? Fluting toolpath came to mind, but not sure how to get curved sides. Moulding toolpath is an other option, but that may be over doing things. Or would it just be eaiser to buy a 3/8" ball nose and be done with it? Not seeing the need down the road too often for a 3/8" ball nose though with what I normally do. This is a one off job and would not pay for a new bit.
- Model of CNC Machine: shopbot desktop
Re: Blood/Juice Groove in Cutting Board
I just use a .5 reg router core bit and sand the sides a little, Ive made hundreds of cutting boards with drip rail.
- WaltS
Thanks for the suggestion. Was trying to use something I had but maybe buying a core bit would make it a LOT easier.
Core bits are cheap.
- Model of CNC Machine: Probotix Meteor, Aspire 8.014
Run a .5 ball nose 3/8 deep. you may be close to what you want or need.
