dust shroud, strip brushes
Okay, here is my first major question, I've had the cnc machine for 1 year, and I'm now wanting to connect my dust system to it, no problem there. What I need is a flexible strip brush approx 4" tall and 36" long I'll cut the length to fit. Can anyone advice. Thank You........Buck
Buck,
If you visit http://www.mcmaster.com/ they should have what your looking for. Just do a search for "strip brush" and you'll see all of the ones that are available.
Mike
Mike
- Model of CNC Machine: CAMaster 508 ATC
for what it worth
i ordered these strips from grainge and they were stiff had tob return it all
check how stiff the material is as when spindle is coming down they can refuse to budge!!
Re: for what it worth
Mcmaster sells them in different materials. I used the thinner of the nylon material in 2" length and they work fine. They also sell horsehair.cabnet636 wrote:i ordered these strips from grainge and they were stiff had tob return it all
BobF
- RoutnAbout
Thank You, Mike and Bill. I have placed an order for the brush I believe will work for my dust shroud. I did find an outlet that had the brush I needed but they wanted to sell me 500 feet, I only need 36" minus.
Best Regards...........Buck
