I tried my first inlay trying the vcarve inlay technique following the hummingbird example - DOC for the carve .2, Start Depth and Cut Depth for the inlay 0.1 each.
On looking at the results I realized that carve and the inlay were not exact mirror images of each other!! Thinking that maybe the carve file had been corrupted or that the CNC had misbehaved, I carved the inlay again only to get the same result.
I then started looking at the preview closely and realized that the error was there too!! I experimented with the inlay start and cut depth and found that it made a difference if I switched to SD 0.15 and a CD of 0.05. (photos attached). Not to sure how this will fit together for gluing purposes, but will give it a go a little later unless I am advised otherwise.
Inlay issue
- FixitMike
Re: Inlay issue
With the inlay cut, the Start Depth sets how far the inlay fits into the carve. If the carve is .2 deep, in my opinion, a Start Depth of .15 to .18 will give the best results. The Flat Depth sets the space between the pieces after they are glued together. Theoretically it can be any number greater than zero. I believe it should be at least .05" to provide space for glue squeezeout. More won't hurt, it just takes a little longer to carve.
Note: Be very sure the glue has cured before removing the excess inlay material. I usually allow the glue to cure twice as long as what the bottle says.
- Model of CNC Machine: XCarve 1000mm and OneFinity Woodworker
Re: Inlay issue
Hi Mike,
Thanks for the advice. Will give it a go and post results...Finger crossed!!!
- Model of CNC Machine: shopbot PRT Alpha 96x48
Re: Inlay issue
Steve,
They are not supposed to be "an exact match" as you see the previews or look at the cut pieces. The male part fits only partway down into the female part. Then the clamping force (lots and lots of it) deforms them together mitigating any CNC errors in cutting. The result should be a seamless inlay.
Paul Z
Paul Z
Re: Inlay issue
I would like to try the inlay technique, and using the hummingbird. is there a source for the hummingbird that is in the tutorial?
- Model of CNC Machine: homebuild / VCP 8.0
Re: Inlay issue
look here..fred ruppert wrote:I would like to try the inlay technique, and using the hummingbird. is there a source for the hummingbird that is in the tutorial?
http://support.vectric.com/tut-vcp-2d-techniques
Re: Inlay issue
If you follow the link that Glenn posted then the tutorial files are there for you to download as well as the tutorial itself.fred ruppert wrote:I would like to try the inlay technique, and using the hummingbird. is there a source for the hummingbird that is in the tutorial?
Most of Vectric's tutorials are like that so you can download the files & follow along.
