I hate to ask such a simple question on here but I want to put an 1/8" circular screw hole at each corner positioned 1/4" (45degrees) in from each corner.
I am sure I saw a video somewhere, whereby I can snap to a corner and specify how far in I want it but I cannot find it. What is the best way to do it?
Circles array from corner point?
- badgersurfer
- Model of CNC Machine: xcarve
Re: Circles array from corner point?
I don't know how to do it in one step but I would offset the rectangle inwards by 1/4" then add circles at each corner. You can also place a circle at each corner then move them. It's a slow method if you have a lot of holes to do. Last, make use of the mirror function for symmetrical shapes to flip about lines (center lines of the rectangle) .
- Alan Male
- Model of CNC Machine: heiz 400T
I'm not an expert here, but one easy way is to use the Offset Selected Vectors icon and create a new profile 1/4" inboard of your existing.
Then you just use the normal Circle icon to snap to the corners of the newly created profile.
Good luck.
Whoops, someone beat me to it
Good luck.
CNC m/c - Heiz 400T
Software - Aspire, VCarve Pro, Photo VCarve, WinPC-NC
CAD - Catia V5
CAD - Catia V5
