Error
- Model of CNC Machine: NewCNC 4x8
Error
Getting this error on 7.5. I reinstalled, but did not uninstall VCarve. Same error
Re: Error
Your best bet is to send an email to support@vectric.com
- Model of CNC Machine: Shark Pro Plus HD
Re: Error
RandyNight
Not sure if this is the same problem I had , but this may be worth a try. Click on and existing file you have already made with Vcarve. This will case the program to use the values this "old" file has and not the one found in the windows regester. If you can open the "old" file be sure to save it with any name old or new. This cleared the problem I had. Good luck
