The attached photos shows a little project I'm currently working on. I made several of these out of wood before making some out of delrin. The drawing I made cut everything out just perfect, however, I'm looking for a different way to cut it out. I cut it out just as you see it on the top drawing and there was no problem. I have VCarve Pro and I'm not sure I can make the cut I want.
I would like to cut this as if you're looking down on the top of it. The top photo is a side view while the other is slightly tilted where you can see the top. I would like to cut the bevel on each side which is a small right triangle that leads down to the half circle bottom. I have never cut a right triangle looking down on it and not sure if VCarve will cut this way.
By cutting it this way, there is less waste.
Thanks for the help.
How do I cut this right triangle?
- Model of CNC Machine: Torchmate
- FixitMike
Re: How do I cut this right triangle?
You can cut this using the FlutePlus gadget. http://paulrowntree.weebly.com/gadgets.html
Thanks, I'll check it out.FixitMike wrote:You can cut this using the FlutePlus gadget. http://paulrowntree.weebly.com/gadgets.html
Have you got a bandsaw? I would cut the blank out first with a bandsaw, then mount them in a pocket on my cnc table. Flute plus for the final pass or two.
What are the dimensions of the blank? Do you have enough Z axis to cut this on edge? It would take some thought to how to hold the workpiece but would make fast work of it.
Tom
Tom
Depending on the dimensions it may be possible to turn the part on the side and machine it with standard XY moves.
- SideExample.crv
- (94.5 KiB) Downloaded 123 times
- rscrawford
- Model of CNC Machine: CAMaster Cobra 408 ATC, ShopSabre IS408
If I were making a lot of these, I'd make a long board in the shape I wanted by cutting the two angled surfaces on my tablesaw with the blade tilted, then using a large ballnose bit on my CNC to machine out the cove, then cutting the parts off the long board on the mitre saw.
Russell Crawford
- Model of CNC Machine: Camaster Stinger
I would like to add to Russell's post a general comment that not every part that can be cut with a CNC router should be cut with a CNC router. This is quite possibly one of those cases. On the other hand, if the only tool you have is a CNC router then every project you come across looks like a CNC application.
