cribbagge Board Holes
I was wondering how to design the holes in groups of 5 for cribbage boards. When I attach the holes to a curved line the holes don't line up next to each other, am I doing something wrong here? I wanted to make different shaped boards for Christmas gifts this year.
- Model of CNC Machine: homebuild / VCP 8.0
Re: cribbagge Board Holes
I'm not a cribbage board maker or player but you should be able to use the copy circles to curve and the linear array tool to create the groups.
Hopefully one of the board makers will come along and give better tips, I have no idea of hole size or spacing but you can set as desired.
Edit, see! 5 rows instead of 3 and can't even spell it right or maybe I did?
- FixitMike
1. Draw a vector that represents the path for the center of the rows of holes. (I'm assuming 4 rows of 30 holes with a space in between along a smooth vector.)
2. Offset the vector, to both sides for half the distance between the rows of holes.
3. Offset the vector to both sides again for the second row of holes.
4. Use the "Copy object along vector" to make 35 copies of the circle size desired. Do each vector separately. You probably won't be pleased with the results.
5. Delete every 6th hole to get the 30 holes spaced in sets of of 5.
6. Or, you can draw the first hole and copy it along the vector 6 times and then repeat with the second hole.
If the pattern consists of straight lines and arcs, do each one separately. You will have to fiddle with the number of holes per line and arc to get the spacing you want and to achieve alignment between rows.
Or, you can simply draw 30 sets of lines crossing the path vectors where you want the holes. Use the Offset and Rotate tools for this. In the Edit menu, Snap Options, be sure the Geometry Snapping to Intersections box is checked. Then draw the holes at the intersections.
You can use the Measure tool, Span Contour Properties to find the length of a vector to help locating the holes.
No really simple way to tell the computer how to locate circles along varying length lines so the pattern looks good.
Thanks...
FixitMike - You lost me on your example, lets say I want to make a path that is for 2 players which would be (2 rows by 5 holes (in this type of grouping)).
- FixitMike
Slightly modified version:
Draw a vector which represents the center of the rows of holes. draw 4 circles at one end to represent the first row for both players. Then group the circles.
Make 35 equally spaced copies along the vector then remove every 6th one to get 6 sets of 5. Copy the circles along the vector (Using the "Copy object along vectors" tool, with the "align objects to vector" box checked.) This will give you the results in the attached picture.
Again, if your path consists of straight lines and arcs, you will have to treat each line and arc separately and allocate the holes according to their lengths to achieve the best appearance. This is because you probably want the rows along the straight lines to be in line, and the rows along the arcs to be on a line drawn through their common center.
Use layers to keep the components separated for clarity as needed.
You can always add your .crv file to a post to help us see the pattern you are trying to achieve.
Ron
The video for that link has been moved or deleted.
Eric
The WoodEraser
Liberty Twp (N. of Cincinnati & S. of Dayton) Ohio
The WoodEraser
- Vectric Staff
- Model of CNC Machine: Saimsmart CNC
Hi WoodEraser,
It seems as though the video is still there, but photobucket is having linking troubles.
If you use the share links to the right, and select the Direct link and then paste that to your internet address bar, this should take you to the video.
- dhellew2
If the arc line is consistent, ie part of a circle, create a circular array then delete the ones you don't need. dh
Young = time, no money
Old = money, no time
Dale
Dale
- P.Passuello
- Model of CNC Machine: Joe's Hybrid
This video may help you laying out Cribbage board.
Cheers
Peter
Cheers
Peter
The ingenuity of idiots is unlimited.
http://www.youtube.com/user/cncnutz
