Help with moving or deleting nodes
If I convert a bmp downloaded from Google to a format that VCW can work with and I have a closed shape that I have way to many nodes to deal with moving, I can 1 redraw object, or 2 drag all the nodes into someway what I want. My question is is there a way of deleting or simplifiying the extra nodes not really needed or wanted for the shape? Imagine a letter L with many outside edges and you only want one of them, but all those outsides are one closed object, that is what I am trying to solve..
- Paco
If there's only a few to remove; in node edit mode, hover over the node and hit 'D'. Caution, hiting 'D' over a span will delete it.
If there's many; I suggest you cut the vector in a way to isolate the unwanted nodes and delete the section then to close the vector after with either straight line, arc or a smooth curve.
Does that help?
Does that help?
