Is their a scale tha tells you the bit and depth how wide
Eddiem
Model of CNC Machine: Romaxx WD-1 and cuttom built 24x48 CNC
Post by Eddiem »
Strange ?
I am working on designing a few custom single line fonts unlike any i have found.
But i want to design them to have 2 or 3 versions that work at different cut depths and for different bit sizes.
One for the 90 bit that works good at .1 and then another version that works good at .2 deep at .2 it covers over part of a .1 when cut.
So if i am using a 90 V bit that is a half inch wide and go .1 and .2 deep how wide will each cut be so i can make a simulation of how it will look in photoshop as i design them so i know how each one will look so i can fix any overlapping areas that are not right for each one.
I plan on making a few different fonts in different styles that are not your normal basic fonts.
Leo
Re: Is their a scale tha tells you the bit and depth how wide
Post by Leo »
A 90 degree V bit is easy to figure.
It will cut twice as wide as the depth you go.
If you go .1 deep - it will cut .2 wide
rscrawford
Post by rscrawford »
It's easy for a 90 degree bit. The width is double the depth.
For other angles of bits, you need to use a bit of trigonometry.
Width=2*tan(1/2 the angle)/depth
Russell Crawford
Tomturner
Model of CNC Machine: Shark MAKO
Post by Tomturner »
rscrawford wrote:It's easy for a 90 degree bit. The width is double the depth.
I think it is the following:
Width=2*tan(1/2 the angle)*depth
The deeper you go the wider it gets and the smaller the v-bit half angle the narrower it gets. A 90 degree bit has a half angle of 45 degrees for which the tangent =1. In that case width=2*depth
A 60 degree vanity has width=2*.577*depth=1.154*depth
And a 45 degree vbit has width=2*.414*depth=.828*depth
rscrawford
Yes, you are correct! Made a mistake in writing the formula.
Russell Crawford
4DThinker
Post by 4DThinker »
All I do when I want to know how wide a bit will cut is draw the profile of the bit, then a line across it offset from the bottom tip to the depth I want. Scissor the overhangs flush to the bit profile and then use the measuring tool to determine the answer. I keep a drawing with all the profiles of the v-bits I have already made just for that purpose.
What I do when making rendered simulations of 2D cuts is to toolpath the vectors and turn on the Solid option. That shows a solid blue outline where the bit can reach.
I then go into node edit and modify the vectors to follow the edge of that and move them in/out where required. Finally I export the vectors as a DXF and render them as objects in my graphics package.
fixtureman
Post by fixtureman »
here is a good chart I have it printed out and by my design computer also a copy beside my control computer
V bit cutting depths & widths.zip
(20.12 KiB) Downloaded 166 times
SIBUD
Model of CNC Machine: ShopBot 18X24 Desktop
Post by SIBUD »
What a typical display of help and generosity on this forum.
I'm continually amazed at the helpful attitude and gracious sharing of information.
Good on ya all!!!!!!
Bud Meade
Nashville, IL
I don't own too many BMW motorcycles, I just have too little time.
Eddiem
Post by Eddiem »
Ok thanks everyone.
I will get working on this and see what i come up with for a new font or 2.
Burchtree
Post by Burchtree »
One more for you. http://www.1728.org/angsize.htm
Dan
People go though many trials and tribulations. Some of them actually happened.
