VCP is dropping letters
sawguy
Post by sawguy »
Can anyone tell me why "VCP" is dropping letters on curve when I program toolpaths All letters are selected, but when you run the preview, it will leave out a letter.http://www.vectric.com/forum/posting.php?mode=post&f=2#
Re: VCP is dropping letters
Post by Rcnewcomb »
Can you post your CRV file?
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Post by jimwill2 »
We could use a little more info... is it possible you bit won't fit inside the letter?
Jim Williams
ssflyer
Model of CNC Machine: ShopBot PRSAlpha 96x60
Post by ssflyer »
Usually happens with a script type font, that has overlapping vectors. You can use the "Edit Text Spacing and Curve" tool, or convert to curves and do some editing to either join or separate the vectors.
Ron Sloan
sawguy
Post by sawguy »
Thanks Ron the spacing was the issue
jhop
Model of CNC Machine: DIY
Post by jhop »
This happens to me when I try to run files that include (high detail) graphic and text in one tool path. It goes away if I process the text file as a separate tool path.
I never thought to post it as I just moved on after it was corrected. Thanks for asking the question. I will be watching for additional answers.
Jim
