Hello
I am from Argentina and I need help because I work with the VCarve Pro and a router (I cut wood). I draw with the Autocad but when I send the files to VCarve Pro, this changes the measures. If someone can help me I will be very greatful
Thank you
PD: Maybe wrote badly because I speak Spanish. Sorry and thank you
I will give an example:
In this morning I designed a circle with 10 cm. of diameter, after I edited this file with the VCarve Pro and when I cut this whit the router it had 9,5 cm. of diameter
Does this happen all the time or just recently? Just a shot in the dark here, But, is there a chance you are using a 1/4 inch diameter cutter thinking it is a 6 mm diameter cutter?
Once the autocad drawing is imported into V Carve Pro, you will able to check the size again. If (1) you set the same tool size in the V Carve Pro as you are actually using on your machine, and (2) have set the tool to cut on the outside of the shape, and (3) your machine is calibrated correctly and is operating correctly, you will get the same size part as your drawing. If any of those three steps are not correct, you may get a size other than that you designed on your autocad drawing.
Espero que esto te ayuda...and I hope my Spanish is understandable.
Hi
That happens to me as well, especially with customers material. I always make a reference square around more complex drawings. When I import this drawing to aspire I select everything and check the measure with the "set size" function, if it is off, I just resize it to the original size. That way all components will have the correct size.
Works with all vector files.
